Proof of Chevy 350 Conversion on D2
Old Nov 16, 2014 | 12:11 PM
  #41
Shade Tree's Avatar
Originally Posted by mln01
At the risk of getting flamed, why not just get a Chevy since the Chevy engine and trans are so good? After all, once you put a Chevy engine in a Rover is it really a Rover anymore?
Ok, I'll take my shot at answering this:
"We don't do it because it is easy, we do it because it is hard."
JFK
Old Nov 16, 2014 | 12:23 PM
  #42
dusty1's Avatar
imo, a little more to a vehicle than just an engine.
I've stuck a 350 and a 327 in a couple of jeeps. (many, many do) it was still a sway prone, bouncy jeep.
same thing here. we weren't offered the more efficient td5. instead we got an underpowered v8 derived from an antique block. it's just a power plant swap. I like the tcase, tranny set up and would like to keep them. but if it were as easy to swap in and adapt, as other platforms, I'd be all over it.
if a man gets an organ transplant from a pig donor, we don't suddenly start thinking of him as a pig
.................................................. .................................................. ....insert bad joke here ^
Old Aug 25, 2017 | 11:38 AM
  #43
99sd's Avatar
Default Trans
Originally Posted by Disco Mike
Here is the big problem, your tranny and the ECU that runs it.Yes, you can put in a 350, along with a GM tranny and t/case but not without basically replacing the entire drive tranny cause you will not have an ecu to run the current Rover tranny.
can't d1 transmission be used
Old Aug 25, 2017 | 12:45 PM
  #44
No Doubt's Avatar
Sure. Or you can use your D2 transmission. Scroll down in this link: Chev Petrol Engines - Bell Housing Adaptor Kits - Engine Conversions
You need the Chev V8 petrol (late) to Rover ZF 4-speed auto bell housing mechanical conversion package/parts.
Obviously you will need a chevy ECU or MegaSquirt if your Chevy 350 is fuel injected instead of carbed.
Post up pics!
jnice
Jul 24, 2016 11:42 AM
TX D2
Mar 4, 2012 11:22 PM
jnice
Jan 14, 2011 10:11 AM
NiteTrain
Aug 14, 2010 12:30 AM
DuplinDisco
Apr 26, 2008 03:14 PM
