Purge Valve/MAF swap question
Old May 15, 2013 | 01:22 PM
russburcham's Avatar
Default Purge Valve/MAF swap question
Been dealing with a slight fuel smell and P0450 code for a few weeks and took it to my indy who told me that whenever you swap out a new MAF or Purge Valve part (which I did), the car's computer needs to be "recalibrated" with a software update form LR. He's telling me its $89 for the software update...
I've never heard of this, but wanted to get a second opinion
Thanks guys!
Old May 15, 2013 | 01:25 PM
ZGPhoto's Avatar
I never did it when I did my purge valve, just cleared the codes and was all good.
Old May 15, 2013 | 02:19 PM
Bob Loblaw's Avatar
So you swapped out the purge valve and then noticed the fuel smell/P0450? Or the other way around? I ask because I am swapping out my purge valve soon.
Old May 15, 2013 | 07:44 PM
I got the code for the purge valve first- swapped it out and then a few days later noticed the smell...I DID use the Hyundai compatible part ($30 compared to $100) then cleared the code only to have it come back- I am going to change out my gas cap next (original) FWIW...
Old May 15, 2013 | 08:06 PM
Rover_Hokie's Avatar
Go Keydets!
Old May 15, 2013 | 10:09 PM
ZGPhoto's Avatar
I used the hyundai part as well, only because there wasn't an aftermarket bosch version available(there is now). It worked without issue or reset.
KlamathMatt
Apr 17, 2020 05:27 AM
austinlandroverbill
Apr 1, 2015 06:26 PM
toofaroffroad
Oct 24, 2014 07:28 PM
rsr50
May 6, 2008 10:55 PM
BuckMontecristo
Jul 27, 2006 10:19 AM
