Question on electrical issue
Old Jul 29, 2016 | 06:15 AM
zuke's Avatar
Default Question on electrical issue
This morning my wipers and windows wouldn't work. Also noticed that the gear selector light showed Park while I was in Drive. I shut it off and restarted and all was good.
As I thought this might be indicative of a failing switch or something, was wondering if anybody had experienced this.
Old Jul 29, 2016 | 10:36 AM
Mskembo's Avatar
Sounds like your XYZ switch is having issues. Some people have successfully cleaned them and had them start working again.
Old Jul 29, 2016 | 11:22 AM
DiscoCam's Avatar
Clean the battery terminals and make sure that they are tight. Loose/dirty battery terminals can cause the issues you have.
It could also be a bad battery. If it is 3 or 4 years old, It's probably time for a new one.
Old Jul 30, 2016 | 06:17 AM
Gravel's Avatar
8th Gear
have you had a leak in the windscreen ,, if so check the fuse box under the dash ,,,, it gets wet and corrodes
Old Jul 31, 2016 | 10:47 AM
Fast951's Avatar
At over $125 for a good Group 34 battery you should have it tested before just replacing. If the battery is failing inside of the warranty period you may have some pro-rated cash coming your way towards the replacement if you decide to go with the same brand.
Old Aug 3, 2016 | 04:25 PM
DiscoCam's Avatar
Pepboys gave me $15 for a 4 year old AAA battery when I bought one of their BOSCH batteries.
mrsharp
Oct 29, 2009 09:22 PM
NATEDOGG
Oct 14, 2009 02:02 PM
toms_disco
Defender
Jan 14, 2009 06:05 AM
jairocol
Feb 19, 2008 05:16 PM
Strider
May 21, 2006 11:57 AM
