question for those with extended radius arms
The amount forward it moves the axle is related to how much lift you have. Measure wheel hubs center to center and it should be exactly 100” with stock height. With a lift if the center to center measurement is 99” then corrected radius arms would move the front axle forward 1/2” as an example. It’s not only the distance moves but more importantly it positions the axle back to the correct castor so that you are not driving on the front edge of your tires so to speak.
me 2 (03-02-2022)
