question for those with extended radius arms
Old Feb 11, 2022 | 03:31 PM
me 2's Avatar
Default question for those with extended radius arms
I was curious on how much forward did the extended radius arms push the front wheels forward? I will get around to some. Thanks for any info.
Old Feb 11, 2022 | 07:37 PM
Alex_M's Avatar
What's the source for them? I had spoken to RTE about making a set several (7ish?) Years ago, but never actually got around to it.
Old Feb 12, 2022 | 07:17 AM
zski128's Avatar
The amount forward it moves the axle is related to how much lift you have. Measure wheel hubs center to center and it should be exactly 100” with stock height. With a lift if the center to center measurement is 99” then corrected radius arms would move the front axle forward 1/2” as an example. It’s not only the distance moves but more importantly it positions the axle back to the correct castor so that you are not driving on the front edge of your tires so to speak.
dicksoutforharambe
Jan 4, 2022 07:35 AM
me 2
Jul 22, 2021 06:55 PM
SundayFunday
Nov 6, 2019 11:56 AM
evansjoem
May 12, 2014 07:59 PM
samsly
Jan 27, 2006 12:14 PM
