questions about my disco 1
Old Nov 22, 2009 | 09:12 PM
JumPeR04's Avatar
Default questions about my disco 1
Hey does the 99 disco 1 come with the jump seats or little cargo space on the side in the back also on the atf is it ok to go wit atf +4 because they don't have any thing but the cheap atf. I need to know how a the main belt should be tight because I think I over tight it
Old Nov 22, 2009 | 09:23 PM
Only a 7 passenger Disco will have the jump seats in the back.
You must use Dexron III in the transmission.
The belt cannot be adjusted, either it is tight or loose, no in between.
If you go to www.atlanticbritish.com and scroll to the bottom of the page you will find "tech tips" and the belt routing will be in there.
Old Nov 23, 2009 | 10:01 AM
okdiscoguy's Avatar
The good news is that you can swap the seats and cargo holders without major modifications. Just swap the parts. On a D2 you have to cut the floor.
Spike got it on the fluids, and you can't tighten the belt, only route it the wrong way.
Old Nov 23, 2009 | 08:23 PM
JumPeR04's Avatar
I seen a 97 wit the little cargo space in the back so that why I ask that questions and about the other ques is because I had to swap out both steer box and pump so when I put the belt back on it whouldnt get tight so I had to pull up on the whole belt tenision unit to just tight the belt and yes I let it run for 10 mins or so to see if it whould tight but it didn't do it so that why I think it is over tight
Old Nov 23, 2009 | 08:37 PM
JumPeR04's Avatar
i seen a 97 wit the little cargo space in the back so that why I ask that question and about the other ques is because I had to swap out both steer box and pump so when I put the belt back on it whouldnt get tight so I had to pull up on the whole belt tenision unit to just tight the belt and yes I let it run for 10 mins or so to see if it whould tight but it didn't do it so that why I think it is over tight plus my rpm ga won't work for about 15 mins then it kick on
Old Nov 24, 2009 | 08:57 AM
hilltoppersx's Avatar
like they said you can buy the jumps seats they are not hard to install on a Discovery 1. all Discoverys have that cargo space in the trunk area. jump seats or not.
gipson
Jul 2, 2009 01:59 PM
gipson
Jun 29, 2009 06:29 PM
avking
Feb 18, 2009 05:10 PM
brianwi11iams
Jul 30, 2005 09:06 PM
duboff
Jul 6, 2005 01:39 PM
