Quick and Dirty QuickFist Brackets 04' D2
Old May 4, 2018 | 07:54 PM
CamelChad's Avatar
Default Quick and Dirty QuickFist Brackets 04' D2
I'm shopping around for roof rack solutions. Given that I can't imagine using it all the time and it may not fit in my garage with it on, I came up with this cheap 20$ solution for taking at least a shovel with me when I go for a trail ride.
Parts:
I found all this stuff at the local Lowes.
1. U-Bolt 2.25" 3/8 Dia x2 (Came with straight brackets.)
2. Extra 3/8 Nuts x4
3. #10 Bolt 1.25"- Bought a pack of six. Used 2 Bolts and 4 nuts from the package. You'll also need 2 washers.
4. Heavy duty...can't remember the size exactly..Heat Shrink Tubing
5. L brackets.
6. QuickFists
Steps:
1. Cut 1.25" off the end of the U-Brackets
2. Using dish soap and water, run it through the heat shrink tubing and slide it onto the U-Bolt.
3. Using a hair dryer or oven, bake the U-Bolt and let the tubing shrink.
I also had some unused weather stripping lying around, so I cut off about 1.5" and used it on the straight bracket of the U-bolt to cushion against the tube.
4. Pick which side of the L bracket you will slide onto the U bolt. You will need to drill out the hole slightly so that it fits the u-bolt properly.
5. Slide the U-bolt over the post and fix your Quickfist to the bracket using the provided washer. Place one of your extra washers on the bottom and tighten with 2 #10 Bolts.
6. Slide the L-bracket over the top bolt of the U-bolt and add 4 bolts to the top and bottom.
***If you have trouble threading the nuts on the U-Bolt after your cuts, use a metal file to grind it down to the next thread edge.
Hope this helps for anyone looking for a quick fix while they shop around.
Old May 6, 2018 | 10:33 AM
Saturnine's Avatar
Nice work!
That picture is reeeeeally small
Old May 6, 2018 | 06:02 PM
CamelChad's Avatar
Thumbs up
Originally Posted by Saturnine
Nice work!
Uploaded a new photo....but for some reason it posted sideways.
Old May 6, 2018 | 09:32 PM
No Doubt's Avatar
Looks good.
I wonder if these 2" diameter LED brackets would work on the front Disco roof bars for the QuickFist bracket?
https://www.ebay.com/itm/LED-Light-B...QAAOSwk95a7XIV
Attached Thumbnails Quick and Dirty QuickFist Brackets 04' D2-roofrackbracket.jpg
Old May 6, 2018 | 09:39 PM
CamelChad's Avatar
I wanted to get those originally. The 2.25” u-bolts I used are VERY snug. I looked at a few other pipe brackets and nothing really seemed large enough. I may modify it later if I can find a better bracket to attach 2 fists to the bolt.
Charlie_V
Aug 22, 2016 09:21 AM
MM3846
Sep 3, 2014 11:43 AM
Fivespddisco
Mar 4, 2013 10:41 AM
Fivespddisco
Dec 31, 2012 04:43 PM
E36 Phantom
Apr 22, 2012 10:39 AM
