Quick Front Prop DS Question
I bought a used front prop drive shaft. The single u-joint at the front of it, was retrofitted with a grease fitting. The double-cardon joint at the rear of the front prop ds is not fitted with grease fittings.
Should I swap out the double-cardon joints with ones with grease fittings, or am I safe with just the front single u-joint having grease fittings?
Thanks!
--Steve
Thanks!
--Steve
No, it came that way from the factory. I have no idea why they didn't make the rest of them greaseable. When new, oem, you have one fitting on one u-joint and on one plug on the slip shaft that you can install another fitting.
Alex_M
11-15-2023 11:08 AM
grandkodiak
03-29-2011 03:04 PM
endneu913
11-03-2007 03:46 PM
