Quick Front Prop DS Question
Old Apr 2, 2012 | 12:27 PM
steveo2000's Avatar
Default Quick Front Prop DS Question
I bought a used front prop drive shaft. The single u-joint at the front of it, was retrofitted with a grease fitting. The double-cardon joint at the rear of the front prop ds is not fitted with grease fittings.
Should I swap out the double-cardon joints with ones with grease fittings, or am I safe with just the front single u-joint having grease fittings?
Thanks!
--Steve
Old Apr 2, 2012 | 12:59 PM
drowssap's Avatar
New u-joints with fitting is a must
Old Apr 2, 2012 | 01:16 PM
jafir's Avatar
No, it came that way from the factory. I have no idea why they didn't make the rest of them greaseable. When new, oem, you have one fitting on one u-joint and on one plug on the slip shaft that you can install another fitting.
Old Apr 2, 2012 | 08:02 PM
antichrist's Avatar
Since it's already out I'd rebuild it, 3 new u-joints and a centering ball kit.
https://landroverforums.com/forum/ge...02/#post164811
Old Apr 2, 2012 | 10:27 PM
EVN137's Avatar
There, you have it. I'm not gonna tell you any different.
All the best.
Alex_M
Sep 7, 2024 05:21 PM
grandkodiak
Mar 29, 2011 03:04 PM
icyhot201
Aug 16, 2010 07:24 PM
blcp86
Jul 24, 2009 07:49 AM
endneu913
Nov 3, 2007 03:46 PM
