Radiator?
Old Jun 24, 2013 | 08:47 AM
zombiedisco's Avatar
I've ordered the radiator. I've already done the 180 degree stat and the HD fan clutch. Thanks for the suggestions though. This cooling system SHOULD be top notch once the radiator is replaced.
Old Jun 24, 2013 | 10:45 AM
Dan7's Avatar
While the radiators from Genesis auto parts ($111-126) fall in the same boat, they do have the added benefit of several positive reviews from this site. If you MUST go with a cheapie radiator, I would go with that one, but a Nissens would be better.
Old Jun 24, 2013 | 12:37 PM
After doing a search and reading reviews, I went with the Niessens. I plan on keeping the truck for some time. Since it only has about 94k now, I hope to double that
Old Jun 25, 2013 | 07:53 PM
MeanSaleen's Avatar
Let us know how it works out after radiator install
Old Jun 26, 2013 | 02:39 PM
Will do, plan on swapping it out this weekend.
Old Jun 28, 2013 | 02:09 AM
jfall's Avatar
yes. Nissens is the best. Thanks Savannah for that suggestion.
Take the rad out as one assy.
Key is taking the horns out. Getting a nut off of a bolt in there - or a bolt out. Forget.
Unhook the 4 hoses by pushing forward on the coupling and unhook them.
On the ground, move all the coolers and parts to the new radiator whilst they are side by side. This is better than fussing with it all in situ.
Old Jun 29, 2013 | 10:18 PM
Alright, thanks for the help everyone. I replaced the radiator and aux fan motor. Not too bad of a job. Temps are consistently around 188-194. Awesome! This is with the hd fan clutch, new water pump and lower temp soft spring thermostat as well.
ferrelltodd
Dec 8, 2005 02:46 PM
SARAH1
Freelander
Oct 30, 2005 12:05 AM
Evian
Sep 10, 2005 01:39 AM
Rcraig
Aug 4, 2005 10:11 PM
nickvillaume
Jul 19, 2005 01:52 PM
