Radio not working, says "code"
Old Jan 19, 2009 | 12:43 PM
larry99discoI's Avatar
4wd High
Default Radio not working, says "code"
Had some work done on 99 Disco, they had to mess with fuses/wiring...now the radio is not working.
When I turn it on the display reads "code". Any ideas for when I take it back to them?
Old Jan 19, 2009 | 12:54 PM
Default RE: Radio not working, says "code"
They cant help you, unless it was a LR dealer.
Look in your owners manual packet.
If it is not in there then you will need to call a LR dealer with your VIN#.
Old Jan 19, 2009 | 01:12 PM
Disco2Guy's Avatar
Make sure you get the exact instructions for entering in the radio code. If you mess up you will need to wait 45 minutes for the system to reset itself.
Old Jan 19, 2009 | 01:29 PM
Rover Chris's Avatar
mine was written under the hood (near the hood latch) and also off to the side of the glove box, may be worth checking out.
Old Jan 19, 2009 | 01:43 PM
Mine is in my audio system owners manual.
There are like 4 manuals in the packet, owners manual, audio manual, Passport to service and the tire liturature.
Old Jan 19, 2009 | 02:02 PM
Disco2Guy's Avatar
After calling the dealer for mine, it's been printed at the top of the work order with the VIN info.
Old Jan 20, 2009 | 02:14 AM
AK Rover's Avatar
Mine was written on a sticky note in the owner manual binder.
jljde
Jul 12, 2013 01:58 PM
mzcharlene
Audio/Visual Electronics
May 23, 2013 09:14 AM
herblatham
Dec 14, 2011 10:17 AM
tads
Sep 14, 2010 02:41 PM
umoms
Apr 3, 2008 06:22 PM
