Radio problems in a 2002 Discovery
Old May 25, 2013 | 11:35 AM
bucklaredo's Avatar
Default Radio problems in a 2002 Discovery
I let my wife drive my discovery, somehow she had problems turning on the vehicle. My father in law went to provide assistance and decided that the battery was the problem. They used jumper cables to try start the vehicle but they could not.
After some hours I was advised about the situation, I went by and used jumper cables to start the vehicle.
Well, after that the radio does not work, fuse is ok and I do not what else to check.
Has some one had the same problem? Please let me know how to fix this issue.
Old May 25, 2013 | 01:08 PM
You will probably need to install a radio security code into the radio to reactivate it.
Old May 25, 2013 | 06:11 PM
bucklaredo's Avatar
Mike, does this mean I have to uninstall the radio to get the code written behind it? please explain how to reactivate it.
Old May 26, 2013 | 09:29 AM
toad2's Avatar
You will have to call a Dealership with your vin #, they will give you the code, you will enter it in to the radio, it will work, all lifes problems have now been solved!
You are welcome.
Old May 26, 2013 | 09:59 AM
And quite often the dealer won't give that information over the phone.
Old May 26, 2013 | 08:26 PM
toad2's Avatar
I have done it twice up here without a problem, depends on the dealer I guess.
Old May 27, 2013 | 05:27 PM
bucklaredo's Avatar
Guys, I got the code from the nearest dealer but I do not know how to do it since the radio is not turning or asking for any code.
is there any procedure or reset button?
Old May 27, 2013 | 07:44 PM
Look for a blown fuse. Attached is procedure, but if it does not display "CODE" then you have other problems.
And there is a lot more than 1 fuse involved.
Fuse links (bolt in fuses under hood) -
Links 1, 3, 7, 8, 12
Under dash fuses F16, F20, F26, F33
Well meaning good Samaritans with jumper cables can blow fuse links with a single glance. Being he is the top mechanic known by SWMBO, no blame must be laid on him, don't even go there. Just fix it, and be happy.
File Type: pdf
Old May 27, 2013 | 10:15 PM
bucklaredo's Avatar
Thanks Savannah Buzz, I will try it and will post results
ninjaff21
Jul 16, 2014 07:29 PM
ckidd
Dec 4, 2008 10:24 PM
merleti
Freelander
Jul 29, 2007 07:50 PM
mvd
Jul 25, 2007 07:10 PM
Orfordrover
Dec 2, 2006 08:44 PM
