Is the Range Rover 4.6 (P38) different than the Disco 4.6?
Old Feb 24, 2013 | 06:43 PM
  #41
toad2's Avatar
Originally Posted by Paul Grant
Some Bosch engines came with Secondary Air Injection, some did not. This difference then extends to the EFI ECU and it's relationship with it's BCU. One has to be careful, all Bosch engines are not the same.
So, Bosch 4.6 out of 99-01 RR HSE will work in an 04 Disco, correct?
Old Feb 24, 2013 | 06:52 PM
  #42
Paul Grant's Avatar
Yes, a Bosch 4.6L from a P38a will work on an '04 DII. However, as mentioned by others, if your DII has secondary air injection you will need retain that system when swapping engines. So, if the 4.6L out of the P38a was not equipped with SAI, and your DII is, you will need to retain the DII heads. Otherwise the EFI ECU for your engine will have issues with the P38a engine's lack of SAI.
Old Feb 24, 2013 | 07:03 PM
  #43
toad2's Avatar
Right. Thanks Paul. Wasn't sure any of the old RR's had SAI as mine does.
Old Feb 24, 2013 | 07:10 PM
  #44
Paul Grant's Avatar
Some did, others didn't. The ports for SAI are in the heads so they are what really matter.
BTW, you should be able to find a good 4.6L engine for a lot less that $5700! AB has re manufactured 4.6 short blocks for $5k. That's re manufactured with zero miles. Give Will Tillery or Marty Powell a call for a 4.6 when you're ready.
Old Feb 25, 2013 | 05:55 AM
  #45
toad2's Avatar
Thanks again.
Rover De Land
Sep 2, 2012 05:54 PM
Lincoln Tarantino
Nov 14, 2011 10:41 PM
elboy0712
May 10, 2010 09:21 PM
d.m.disco
Mar 15, 2010 09:21 AM
mattrickman
Sep 9, 2008 12:32 PM
