Range Rover tubular headers in a Disco
Old Nov 12, 2017 | 06:33 PM
coastie's Avatar
Default Range Rover tubular headers in a Disco
While at a junk yard I looked over a couple of 99 range Rovers both of which had tubular headers. The engines were 4.6 Bosch's
My question is will the headers fit/work in a '03 D2 ? How much modifying would it take to make it work?
Old Nov 12, 2017 | 10:18 PM
Alex_M's Avatar
I'm assuming you mean the shorty headers that came on them from the factory.
They'll bolt onto the heads and if I had to guess I'd say they'll clear everything, but they won't bolt up to the exhaust.
What's your intent in swapping? If its power gains, don't bother. The difference would be negligible. If you're going to go through the effort of doing headers then go all the way for long tubes.
Old Nov 13, 2017 | 05:11 PM
No Doubt's Avatar
217 hp vs 225 hp, right?
Old Nov 13, 2017 | 05:57 PM
Alex_M's Avatar
Not exactly sure what the numbers are, but I know the P38 also got a little more timing advance which was supposed to give it a touch more power. At least that's what I've been told.
Old Nov 13, 2017 | 06:00 PM
No Doubt's Avatar
Spark advance and cam/valve advance or just one of those 2?
Old Nov 13, 2017 | 08:34 PM
Alex_M's Avatar
Spark advance I believe. And actually, from what I've heard you can swap the ECU from the Bosch powered P38s.
Old Nov 13, 2017 | 09:09 PM
No Doubt's Avatar
Neat tip!
Jeff Blake
Dec 31, 2016 05:19 AM
Alex_M
Feb 25, 2015 04:17 PM
PFS
Apr 6, 2013 09:57 PM
sonic77
Oct 4, 2008 11:22 PM
Aj6543
Oct 2, 2008 01:51 PM
