re aline steering
![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
Check the bar that connects from the steering box to the passenger tire. If it is bent, replace it. It is the drag link. If it is not bent, you can loosen the end link clamps and turn the bar. It has a RH thread and LH thread ball joint on each end. If you turn it one way, it will expand, and contract the other way. This is how you align your steering wheel.
Check all of your ball joints while you are under there and chack that your pitman arm is tight.
jycsalas
04-17-2009 02:21 AM
Evian
08-18-2005 11:34 PM
