Rear Brake Caliper removal
Old Nov 8, 2015 | 04:54 AM
Coldmieser's Avatar
The bolt heads are stripped, rounded and shiny, hard to get any kind of socket to stay on without slipping off, I'll keep at it and try the Heat/freeze method. Thanks again,
Old Nov 8, 2015 | 12:12 PM
batard's Avatar
As a last resort, you can of course drill them out, though I'm not sure how easy they'll be to reach with a drill. Use a center punch to center the bit and start small, working your way wider until it flakes out of there.
Old Nov 8, 2015 | 07:30 PM
ATLDisco's Avatar
Get a set of bolt extractors. They work miracles.
I snapped the glow plug off in the head on my old mercedes, and they saved my tookus.
If you wrench on anything, and don't own a set, I question your sanity.
amazon has best pricing on them from what I can tell.
Torch the SURROUNDING METAL, not the bolt, propane is OK, doesn't get that hot though. try a blue wrench.. (oxy/ace) and repeated PB blaster or deep creep treatments.
Sharp blow to get it started, then steady pressure.
Get some GOOD anti-sieze after that (I use nothing but liqui-moly) and new bolts.
Giddyup!
pottzie
May 15, 2013 02:32 PM
jm12503
Jun 25, 2009 10:02 AM
mburnett
Apr 20, 2007 03:09 PM
i_m_jon
Mar 16, 2007 09:42 PM
