rear door stuck
Pop the Land Rover emblem off of the rear door handle with a screw driver.
Spray the handle with silicone spray.
Work the handle.
Spray again.
The door will open.
This is common on ALL trucks with this type of cargo door and the handle, hinges and door slide need to be lubed at least every 6 months.
More often if you live on a dirt road or in the winter time if they use road salt.
It is recommended that you lube ALL hinges on your cars every 6 months.
Silicone spray will not attract dirt like WD-40 will for example.
Work the handle.
Spray again.
The door will open.
marlymarl
07-28-2005 12:23 AM
