rear door stuck
Old Sep 29, 2015 | 07:49 AM
MPDano's Avatar
Originally Posted by jimvw57
Mine only gets stuck after I put something big enough in there that I can't get out the side doors. A shot of penetrating fluid, wait 15 min and it opens right up. I tried using some motorcycle chain lubricant this time to see if it lasts longer... time will tell.
Ha ha. I too was looking at my chain lube before I grabbed the silicone spray.
Old Sep 29, 2015 | 01:27 PM
georgep's Avatar
Originally Posted by Spike555
Pop the Land Rover emblem off of the rear door handle with a screw driver.
Spray the handle with silicone spray.
Work the handle.
Spray again.
The door will open.
This is common on ALL trucks with this type of cargo door and the handle, hinges and door slide need to be lubed at least every 6 months.
More often if you live on a dirt road or in the winter time if they use road salt.
It is recommended that you lube ALL hinges on your cars every 6 months.
Silicone spray will not attract dirt like WD-40 will for example.
WD-40 took a 10 min soak and POP goes the door!!!
ImQuattro
May 1, 2014 08:36 PM
rookie
May 10, 2008 03:07 PM
kbryant31
Feb 6, 2008 08:02 PM
Dahne23
Sep 7, 2007 08:41 AM
