Rear Heated Windscreen Fuse Blowing
2001 DII SE
The heated rear windscreen fuse (#8 in the box inside) keeps blowing when I push the activation button. I have a crack in the passenger side front windscreen and I thought that might be the problem because the wiring diagram looks like the rear and the passenger front heating elements are connected on that fuse. However, I disconnected both sides of the front windscreen leads inside the engine compartment and the fuse is still blowing. Any suggestions of where to start?
