Rear Heated Windscreen Fuse Blowing
Old Mar 14, 2013 | 12:05 AM
gundog's Avatar
Default Rear Heated Windscreen Fuse Blowing
2001 DII SE
The heated rear windscreen fuse (#8 in the box inside) keeps blowing when I push the activation button. I have a crack in the passenger side front windscreen and I thought that might be the problem because the wiring diagram looks like the rear and the passenger front heating elements are connected on that fuse. However, I disconnected both sides of the front windscreen leads inside the engine compartment and the fuse is still blowing. Any suggestions of where to start?
Old Mar 14, 2013 | 12:12 AM
bballjames's Avatar
I have the same problem. I don't use my rear defrost anymore. Problem solved
Old Mar 14, 2013 | 12:47 AM
Fuse 8 (30 amp) on the inside box is for the rear screen - and heat elements in outside mirrors. Outside mirrors can have that element dropped off at header connectors under kick panel.
Fuse 8 (40 amp) in the underhood box is for the heated front screen - right hand.
Old Mar 14, 2013 | 12:57 AM
909wheeler's Avatar
Make sure no aftermarket electrical (radio, alarm, etc) has not tapped that circuit for power. If tapped, the fuse will blow. Lazy stereo installers like to tap into rarely used circuits rather than run the appropriate wiring.
Spinvestigations
Jan 31, 2014 10:49 AM
cgap
Dec 4, 2011 12:18 PM
mcwilly21
Jan 30, 2011 09:36 PM
mutley-uk
Oct 22, 2010 02:14 PM
skswindon
Dec 16, 2006 12:15 PM
