Rear Park Assist
Old Oct 10, 2015 | 04:06 PM
Jag100's Avatar
Default Rear Park Assist
Searched the DII forums, and did not readily see anything on this. Is it possible/practical to add the rear park assist option onto a 2004 Disco SE? Would it typically be prewired for this? Vehicle is for my daughter, and just trying to give her a slight edge in that department...............Thanks.
Old Oct 10, 2015 | 04:27 PM
abran's Avatar
I believe the connector for the button on the dash binnacle is present, but the harness at the rear to the sensors is not.
Even if you succeed to adding all the hardware, the software will have to be activated in the BECM.
Old Oct 10, 2015 | 06:12 PM
Jag100's Avatar
That is a great point. Thanks.
Old Oct 12, 2015 | 06:55 AM
PaulMc's Avatar
An 04 vehicle will be wired from the binnacle to the LH rear wiring compartment.
There will be a pre-wired switch connector clipped into the rear of the switch blank in the bottom left position in the binnacle.
Behind the LH grill in the load compartment, you'll find the connectors for the PDC ECU -
C0957 and C0958 are for the PDC ECU
C0987 is for the PDC speaker
Here's a clearer picture of the three connectors -
You will also require the rear bumper harness and sensors.
Underneath the vehicle, in the LH rear corner, you should find the 6-way connector where the bumper harness connects -
From Land Rover - Part number YMD001410 (callout 1) -
YMD001410 | REAR PARKING SENSOR LOOM DIS11 | Land Rover | Discovery 2 - 1999 to 2004 | Britcar (UK) Ltd
Unless you can pickup the parts cheap from a scrap yard, they cost a fortune new from Land Rover.
You would be better off fitting an aftermarket kit from eBay.
If you were to fit an aftermarket kit, there's an ignition-switched live (Light Green/Orange trace), and reversing lights circuit (Green/Brown trace) in C0958
Old Oct 12, 2015 | 09:07 AM
Jag100's Avatar
Wow, Paul. Thanks so much for the info. I will let you know how I fare.
Thanks
Old Oct 12, 2015 | 10:15 AM
PaulMc's Avatar
Thanks
Please do Name:  icon_thumbup.gif
If you have any questions, I'm alway happy to assist, if I can.
Old Nov 9, 2015 | 12:12 PM
Jag100's Avatar
Paul,
That one did not work out. Looking for another. Thanks
Stan
Old Nov 9, 2015 | 04:53 PM
redrover75's Avatar
Default Camera
Why not just buy one of the aftermarket camera kits? I would bet for the time and money you would have a better result.
Old Nov 9, 2015 | 05:43 PM
Jag100's Avatar
I know. I just have this thing about originality. I make it hard sometimes.
Thanks
Old Nov 9, 2015 | 06:25 PM
jafir's Avatar
The part number for the kit is STC50424AA. It's crazy money new. It would probably be easiest to find an HSE and rob all of the parts.
amer_qureshi
Jul 10, 2024 02:03 PM
derohanes
Aug 24, 2012 09:17 AM
luxury1
Dec 16, 2008 02:13 AM
bhorwhat
Sep 28, 2008 03:01 PM
wesk
Aug 17, 2007 12:14 PM
