Rear Suspension Knocking?
Old Nov 15, 2011 | 04:41 PM
LR03NJ's Avatar
Default Rear Suspension Knocking?
I found this thread message:
Is your truck lifted, if so it "could" be your rear shocks are "topping" out, usually occurs over bumps and with a lift and on the rear of the vehicle.
-I have 2" OME lift and will that cause shocks to top? What is the remedy? I hear them getting loud even on small bumps and puddle and sound like dribbling from the rear. Advice needed.
Thanks
Old Nov 15, 2011 | 08:03 PM
NiteTrain's Avatar
get new shocks made for a 2" lift
Old Nov 15, 2011 | 09:24 PM
jeffh's Avatar
what spring to you have on your lift. If you are not "loading" the springs with the minimum rated weight you can cause this scenario...I swapped out my heavy duty constant for medium duty once I stopped traveling with enough weight and the ride became so much smoother. Just a thought.
Old Nov 16, 2011 | 08:44 AM
coors's Avatar
Thanks
Makes sense. I think i have this same issue. I bought the truck used the previous owner removed the air bags and replaced w/ springs. The truck def has a lift (2") not sure if they just replaced the springs and left the stock shocks in. But, every time I turn to go down my driveway the rear of the truck makes this awful knocking when its rocks back-and-forth.
Maybe it's time for new suspension all around
Old Nov 16, 2011 | 10:38 AM
If you are running a medium or HD OME suspension, their OME Sport shock ar plenty long enough to prevent over extending .
More likely you have a rear bushing issue, be it the Watts bushing, shock bushing or trailer arm bushings.
Old Nov 17, 2011 | 04:24 PM
LR03NJ's Avatar
I'm running with a 2" medium OME. I am wondering if there is a softer ride for a 2". Checked the shock bushing or trailer arm bushings in Atlantic British and none for Disco 2. Where to get? thanks
Old Nov 17, 2011 | 07:42 PM
jeffh's Avatar
call justin at lucky 8.. but you need to know what springs you have front and rear... there are little tags on the springs themselves that have numbers.. 761, 762, etc.. get those first as they will let others know their weight designation.. Justin will be able to get you sorted out with the right springs for your needs and weights.
Old Nov 18, 2011 | 09:42 AM
Why are you wanting soft, have you ever driven a Disco with a medium duty suspension? Going softer give you an uncontrolled top heavy feeling when driving. Now if all you are going to do is drive around town and you are not wanting a lift then just buy the OME Sort shock which will greatly improve your ride. If you still have a noise then you will need to have someone help you find the bad bushings or possible broken spring.
mowensmd
Aug 21, 2024 11:07 AM
fso
May 11, 2015 03:04 PM
Dtrain36
Mar 5, 2015 07:43 AM
jamiederr
Oct 31, 2010 03:00 PM
LR03NJ
Mar 5, 2010 07:37 AM
