Rear window rolls down but not up
Old Aug 31, 2021 | 01:21 PM
Goose95's Avatar
Default Rear window rolls down but not up
Hi guys,
When I bought this D2 a few months ago, the rear passenger window worked fine. It stopped working about a month later and would go down but not up. Then it eventually stopped working at all.
I just replaced the window motor and regulator and now the window is back to going down but it won't go back up.
Any ideas??
Old Aug 31, 2021 | 03:15 PM
acg's Avatar
acg
Is the replacement motor a used motor unit?
It may be the gears in the used motor unit may be stripped. Same issue with the original... would go down, but not up. I had to change to a new motor with working gears to make mine work a couple of years ago.
Old Aug 31, 2021 | 04:53 PM
The Deputy's Avatar
Did you check the switches? New window regulators may have tolerated poor continuity, but eventually disliked resistance of poor contacts within switch.
Old Sep 1, 2021 | 11:03 PM
Goose95's Avatar
@acg
I bought the motor and regulator straight from Lucky8. I tested using the other rear windows motor and still had the same issue.
@The Deputy
I have moved the switches around (from rear to front, and swapped the sides) and had no luck there either.
Old Sep 2, 2021 | 02:45 AM
The Deputy's Avatar
I guess the next place l'd check would be harness, from switch to regulator, especially between door frame and door.. It's possible a wire could be rubbed through, partially, not giving enough amperage to motor. Takes a lot less amperage to lower glass than to raise.
Granted, could be a bad motor, parts nowadays are garbage for the most psrt...no matter where you buy (not picking on Lucky 8).
Old Sep 6, 2021 | 08:10 AM
Extinct's Avatar
did this get solved?
Goose405
Jun 12, 2021 08:38 PM
zuke
Oct 4, 2020 12:44 PM
gte619n
Jul 7, 2018 02:03 PM
Toyfare
Jul 13, 2013 10:38 AM
marcwestbmw
Oct 2, 2008 09:43 PM
