Rear wiper...
Old Mar 5, 2023 | 10:19 AM
Externet's Avatar
Question Rear wiper...
Hello.
How to remove the rear wiper blade section only, not the arm ? ( Separating the wiper from the arm )
Old Mar 6, 2023 | 01:22 PM
Externet's Avatar
Solved. Brute force pops out. Replaced the rubber only. All OK.
Old Mar 6, 2023 | 10:04 PM
nashvegas's Avatar
Technically if you're doing it "by the book", on a D2, you need to remove the rear spare tire to pop out the wiper blade from the arm... But I've done a bit of bending and made it work.
The issue with bending the arm slightly ... is... often after you do so, the wiper stops touching the window for its length. Just that slight bend in the plastic wiper arm gets it away from the glass a bit and you'll not be happy with the wiping performance, new blade or not.
BritCars
Dec 24, 2021 11:43 AM
EastCoast
Apr 5, 2018 08:50 AM
prroverguy
Apr 18, 2013 09:36 AM
discoboy
Dec 15, 2008 03:22 PM
wizardmagu
Nov 11, 2008 11:18 PM
