Rear wiper modification how-to
Old Apr 18, 2013 | 09:12 AM
prroverguy's Avatar
Default Rear wiper modification how-to
Frustrated that I couldn't find rear wiper blades locally, and that none of the inserts would fit into POS plastic (can you see my hatred and discontent towards plastic components yet?) wiper blades, I ventured to do what no one has done. Fitting "normal" steel, locally available blades into stock rear wiper arm... Now if I could find a steel wiper arm that would fit... Purists need not read further!
Old Apr 18, 2013 | 09:14 AM
prroverguy's Avatar
1. Remove spare wheel, and #13 nut that secures wiper arm to its axle.
Old Apr 18, 2013 | 09:15 AM
prroverguy's Avatar
2. Pop off stock wiper from its clip careful not to break POS plastic arm/clip.
Old Apr 18, 2013 | 09:18 AM
prroverguy's Avatar
3. Cut a vertical "notch" across wiper arm until about the depth of thinner wiper clip. Use the following picture to reference where to cut.
Old Apr 18, 2013 | 09:20 AM
prroverguy's Avatar
4. Cut horizontally from the outer thinner clip end until you reach your vertical notch. Do it nice and pretty.
Old Apr 18, 2013 | 09:23 AM
prroverguy's Avatar
5. Repeat on opposite side. Now, take your choice of sandpaper and sand cut areas until smooth.
Old Apr 18, 2013 | 09:32 AM
prroverguy's Avatar
6. Match your new rear wiper blade to arm, I found out that if it doesn't want to go in one way, just flip it and it should pop in. I used channel-lock pliers to aid in seating new blade into its retaining slot.
Old Apr 18, 2013 | 09:36 AM
prroverguy's Avatar
7. Repeat disassembly instructions in reverse order to reassemble everything back together (usually how it always works). Drink beer and be proud and happy now you can locally find a cheap steel wiper blade, or simply swap a new refill into your "normal blade"
toofaroffroad
Aug 7, 2015 09:17 PM
bcolins
Feb 2, 2014 09:40 PM
bcolins
Jun 22, 2013 08:55 PM
justfred
Mar 12, 2007 10:20 PM
anonimaus
Sep 19, 2005 01:25 AM
