Removing Catalytic Converters?
Old Oct 23, 2015 | 11:09 AM
kfx4001442's Avatar
Default Removing Catalytic Converters?
4.0 Bosch engines. 2000 D2 and also a 1999 p38. Anyone have any experience with running without the Catalytic Converters on the trucks? Anyone sold theirs before? If so, where and how much did they bring?
Old Oct 23, 2015 | 11:24 AM
OverRover's Avatar
Without cats, get ready for it to stall at stops like crazy. You will only make this mistake once.
Old Oct 23, 2015 | 11:48 AM
kfx4001442's Avatar
Why do you think it will stall? I understand it may use more gas without them, but if an o2 sensor fails on a disco it doesn't make the truck stall.
Old Oct 23, 2015 | 12:13 PM
Street Wolf's Avatar
That's literally one of the more stupid things I've heard in a while. No car will "stall at stops" just because you remove the cats. Maybe someone needs to be a little more mechanically inclined before trying to give advice.
On another note, you won't notice much difference with or without them. I've been running catless for about five years now ever since I put headers on my Disco and redid the entire exhaust system to go along with it.
Only drawback is you might throw a o2 sensor code from time to time, not an issue if you have a Scangauge tool or trick the rear o2 sensors to read correctly.
Old Oct 23, 2015 | 12:27 PM
Alex_M's Avatar
I sold mine for scrap, $60 each. You can put some long 90 degree spacers in the rear O2 and be good to go, you can find them on eBay. It's an m18x1.5 I believe.
Old Oct 23, 2015 | 08:53 PM
marizcal's Avatar
hey Alex could you post a pic of that 90 degree spacers??? or the link??? I am interested. I do a seach but they are in different lengths.. so wtich one is the good???
I run my disco 2 with out catalytic converters,, and always have the check engine on.. will this help with this issue...??
thanks,, regards
Old Oct 23, 2015 | 09:42 PM
Alex_M's Avatar
Sure! This one here would work. Typically just the longest one you can find is best, but this one looks good.
SDT M18X1 5 90 Degree Angled O2 Oxygen Sensor Bung Extension Spacer | eBay
m1943
Aug 24, 2019 12:47 AM
targotsi
Oct 23, 2015 11:40 AM
DuplinDisco
Jul 20, 2008 03:25 PM
jdhuegel1
May 6, 2008 06:09 AM
jdhuegel1
Apr 29, 2008 03:58 PM
