Replace Cam & Lifters??
I recently picked up an '02 DII with a blown engine (shot rod through block).
I have a replacement low mileage replacement long block ('00 with only 90k on it). I have had the heads gone through and I have read the sticky about rebuilding the engine.
My main question is should I replace the cam & lifters from this replacement long block? It was a known good engine and with 90k on it does it warrant it? I'm not against spending another $500 but if it's not warranted then I won't.
How far do you want to go .... that is the Million $$ question that I'm trying to figure out.
The bottom end was solid, which is why I got it, so I'm just trying to figure out far to take it. Unless there is a known issue with cam/lifters I'd rather save my $$. At the same time, I don't want to go through all this work only to regret it in a few months.
As for the oil PSI test I had plans to just replace the oil pump anyway. Is this something I should reconsider if the PSI tests ok?
While the motor is out mayswell do all new bearings, crusifix seals, rear main seal and oil pump.
the stuff is cheap and you will have a "like new" motor. If the cam is fine i'd just put new lifters on it. The cam does not "wear out", the hard surface of the cam grinds off due to lubrication issues (low oil pressure, thin oil, low zinc/molly oil) and a lobe goes round in about 100 miles.
What would be the intent of doing all bearings? If the oiling issue was not a problem, to warrant a cam as you suggest, then why would the bearings be suspect?
Additionally, all "old school" rules say that if you replace cam/lifters as a set. Why would that theory not be followed here?
I understand all of the seals and am planning on that as well.
