Replaced coolant reservoir
Old Jun 15, 2018 | 06:44 PM
foxfist13's Avatar
Default Replaced coolant reservoir
The connection behind it
New coolant reservoir
I replaced the coolant reservoir and notice this hook up behind it it looks like it goes to the throttle is the line suppose to have a connection to the boot. This is a 2004 discovery II.
Old Jun 15, 2018 | 10:39 PM
abran's Avatar
If you are talking about the accordion boot, that covers a cable that is connected to the cruise control diaphragm.
but now, let’s address the elephant in the room!
which coolant tank is that and how muchey?
Old Jun 15, 2018 | 11:14 PM
Saturnine's Avatar
Is there a sight glass on it?!
Old Jun 16, 2018 | 01:42 AM
shanechevelle's Avatar
Similar ones are around $150.
Old Jun 16, 2018 | 01:12 PM
foxfist13's Avatar
I paid $260 for the tank, a private Land Rover repair shop in Roswell, Ga has them custom made.
Old Jun 16, 2018 | 01:13 PM
foxfist13's Avatar
No it has a shelf inside to that is used as a indicator for the reservoir when it’s full. But you can’t see unless you crack the lid.
Old Jun 17, 2018 | 02:36 AM
JUKE179r's Avatar
For $260 it better bleed the system itself and monitor the engine temperature.
Looks cool tho. Is it an AlliSport?
Old Jun 17, 2018 | 02:56 AM
OffroadFrance's Avatar
I can see an issue! How do you check at a glance whether there is coolant in the header reservoir (when hot) and whether the water pump is circulating the coolant correctly OK. Alloy header tanks have been around for most vehicles and have been for years and most suffer the same issues.
Seems expensive!
https://www.allisport.com/shop/perfo...5-header-tank/
Old Jun 17, 2018 | 06:32 PM
foxfist13's Avatar
No it was custom made by a local Land Rover mechanic shop. Or at least that’s what they told me. It was a lot more then I wanted to pay but I needed something quick and this was available.
Old Jun 17, 2018 | 06:55 PM
Best4x4's Avatar
Make sure if you get the Allisport unit to get one with the lower nipple unless you completely bypass the intake line/TBH.
abran
Dec 28, 2018 01:41 PM
Sunflower
Nov 10, 2018 02:05 PM
mollusc
Jul 28, 2018 10:24 AM
Rearden Steel
Jan 29, 2012 11:39 AM
joshluseal
Mar 15, 2011 07:33 AM
