Replacing caliper boots?
Old Nov 21, 2014 | 11:00 AM
  #21
Motorhead1's Avatar
How did they come apart? Were they sticking to begin with? Is that the cause for the rebuild? If so, you can use a brake wheel cylinder hone, and lightly, and breifly hone the inner bore of the caliper using a drill and some brake fluid. You want the piston to slide in nice and easily, no bounding up, thats what causes the sticky calipers everyone seems to get eventually. Give that a shot
Old Nov 21, 2014 | 11:03 AM
  #22
drowssap's Avatar
honing will do you no good the piston does not ride in the bore, it rides on the seal.
you are correct you should be able to get them back in by hand, there should be no need for a c-clamp.
even if you managed to get them in with a c-clamp the odds are the they would not come back out if the fit is that tight.
Old Nov 21, 2014 | 11:30 AM
  #23
OilPatch's Avatar
Any suggestions on where I can get rebuilt calipers? I've looked around and they seem pretty pricy. I've seen some people talk about core charges
Old Nov 21, 2014 | 12:10 PM
  #24
T.J.'s Avatar
Order a set of semi-loaded calipers from Rockauto. They include all hardware including guide pins and boots and cost about $40 after you return your old caliper. A core charge is like bail until you send them your old caliper. Much easier than rebuilding.
Old Nov 21, 2014 | 12:14 PM
  #25
OilPatch's Avatar
Awesome thanks man!
Old Nov 21, 2014 | 12:43 PM
  #26
Motorhead1's Avatar
The square cut "rubber" seal was causing the piston to bind so badly that it wasn't able to get forcefully pressed in with a c-clamp? Sure... Metal on metal is what causes this issue...
Maybe they sold you the wrong rebuild kit Oilpatch?
Were all just pissing in the wind without pics anyway....
Thats a good deal at RockAuto, Brake on!
dms6601
Aug 22, 2013 12:24 PM
Bundu
Jun 14, 2010 03:53 PM
malmberg
Aug 9, 2009 07:57 PM
jycsalas
Jul 21, 2009 02:32 PM
