Replacing Fuel Injector Seals-need advice
So I've been working for about 5 hours today. Changing plug wires and plugs took up a lot of that time. That's done and I'm about to change the injector seals, but I'm working outside and it started to rain so I am done for the day.
The injector rail bolts were really rusted and I snapped off the 2 on the drivers side. I got smart for the passenger side bolts and soaked them with PB Blaster and eased them out ok. Can I live without those 2 driver side bolts or should I drill them out and replace them?
Thanks Guys!
Thanks Guys!
Thanks MPDano......another quick question. Do you need a special tool to unclip and reclip the electrical connector at the injector? I remember having problems with those type of connectors in other cars I've worked on.
Thanks!
Thanks!
These plugs are different. They have a metal clip around the plug that has to be released....same as the one in the pic (obviously not an injector plug, but the same type of connector)
...and if this doesn't work, you could just pry the metal bar off carefully and then the plug will release. Sometimes just pressing on the bar doesn't fully release at the plastic tabs. You can put the metal bars back on after the plug is removed.
