replacing head gaskets etc
Old Mar 23, 2016 | 04:53 PM
blackwolf's Avatar
Default replacing head gaskets etc
Hi all, I am replacing head gaskets and plenium gasket the plenium gasket is the black composite one ! Do I need to use gasket sealer with this or not? anyone know ! Thanks My Regards to you all.
Old Mar 23, 2016 | 06:09 PM
jamieb's Avatar
No. Just lay the plenum gasket on top. Should not need sealant. My plenum gasket almost felt like metal it was so stiff
Old Mar 23, 2016 | 06:58 PM
jamieb's Avatar
Are you doing head gaskets or valve cover gaskets?
Old Mar 23, 2016 | 09:02 PM
blackwolf's Avatar
Hi jamieb , and thanks for your reply ! I messed up in my post ! I MEANT VALLEY GASKET ! I have this valley gasket totally covered in some kind of composite ! and I am not sure if i should use sealant ? I have read all i can . Most people say use sealant in the 4 corners of gasket and on the 2 rubber end peices where the bolt on metal pieces are ? if you know better ! I most certainly would like your advice ! . Many thanks for your reply ! Greatly appreciated . Kindest regards Nick.
Old Mar 23, 2016 | 10:14 PM
XCELLER8's Avatar
no sealant needed on "most" of the valley gasket.....except put some in the corners where the heads / intake manifold / rubber end caps all meet....there is usually a very small gap there and the sealant will help keep it from leaking oil there.....give it a dry fit first( just set the manifold in place) to determine exactly where and how much to use
Old Mar 24, 2016 | 01:00 PM
acamato's Avatar
I used RTV around the water jacket ports.
https://cannibalv8.wordpress.com/sho...ket-end-seals/
achapman
Jun 25, 2013 03:40 PM
06Range
May 8, 2013 09:01 PM
TheBelly
Nov 1, 2010 08:34 PM
lipadj46
Jun 17, 2009 08:41 PM
drhunter
Mar 21, 2007 07:21 PM
