Reverse brake bleeding
Old Jul 4, 2019 | 02:26 PM
Spam2021's Avatar
Originally Posted by Best4x4
You use the Front & Back terminals once you remove the ABS relay. Then you make sure your reservoir is full, climb under the D2, flip your toggle switch, ABS pump will run, open the bleeder and flush the old fluid or air out. Tighten the bleeder, top off the MC, and move onto the next wheel. Quick and easy way to power bleed a D2 without any fancy scan tools.
Thanks, that is awesome info.
Old Jul 4, 2019 | 02:32 PM
Best4x4's Avatar
No problem at all!
Old Jul 4, 2019 | 03:16 PM
JUKE179r's Avatar
Jupiter Rover
Feb 27, 2009 01:04 PM
sharp
Feb 7, 2009 10:00 AM
sdsilvere38
Sep 2, 2008 09:35 AM
KeizerRover
Mar 15, 2008 01:24 PM
mwyrick45
Feb 7, 2008 11:24 AM
