rim question
Old Jan 23, 2015 | 06:34 PM
stb616's Avatar
Default rim question
The rims on my 01 are a little "bruised."
A local ad says they're selling a set of these at a good price (from an 03 Discovery). The seller wasn't sure, but I'm assuming these are 16's, correct? And they'll fit on my 01? Just want to be sure before I drive over there.
Thanks
Old Jan 23, 2015 | 07:11 PM
dgi 07's Avatar
Those maybe 18s..but yes, they should fit.
Old Jan 23, 2015 | 07:13 PM
wynhd's Avatar
Those look like 18's and with would fit. My wheels look similar, and are 18's. I have seen locally someone selling a set like those, claiming they were 16's. Is it possible they are from a Freelander?
Old Jan 23, 2015 | 07:14 PM
OverRover's Avatar
I've been drinking, but are you sure those aren't FREELANDER wheels?
2003 Land Rover Freelander 16x6-aluminum-alloy-5x114mm-bolt-pattern-wheel-rim-72167
Land Rover FREELANDER 2002 2003 2004 2005 72167 Aluminum Alloy 16x7 5-114MM 5 Grooved Spoke Wheel Rim
WYNHD.. I think we hit enter at the same time.
Old Jan 23, 2015 | 07:43 PM
stb616's Avatar
I was wondering if they were from a Disco or not. The ad says Discovery.
Anyone know for sure how to tell?
Old Jan 23, 2015 | 07:59 PM
OverRover's Avatar
Look in the inside the part # and size should be there.
But I think you are looking at part # ALY72167U20 which are 16" off a freelander.
Wheel Diameter: 16
Wheel Width: 6
Wheel Size: 16x6
Number of Lugs: 5
Bolt Circle: 114mm
Bolt Pattern: 5x114mm
Offset: 46mm
Material: Aluminum Alloy
Piece: One
Design: 5 Spoke
Placement on Vehicle: Universal
Features Included: Grooved spokes and dimples between lug openings
What you are looking for is part # ANR4849MNHG 18" for a DII.
Amazon.com: 18 INCH 1999-2004 LAND ROVER DISCOVERY OEM ALLOY WHEEL RIM 72158 ANR4849MNH 18X8 99 00 01 02 03 04: Automotive Amazon.com: 18 INCH 1999-2004 LAND ROVER DISCOVERY OEM ALLOY WHEEL RIM 72158 ANR4849MNH 18X8 99 00 01 02 03 04: Automotive
Wheels For Land Rovers - 18 X 8 Proline - Genuine
Now back to my regularly scheduled drinking.
Old Jan 23, 2015 | 09:10 PM
abran's Avatar
18" are called Proline, 16" are called Lightning.
Both are D2 and P38 compatible.
yloDiscoII
Aug 26, 2011 10:41 AM
DonRW2007
Aug 18, 2011 10:36 AM
salve7
Dec 2, 2009 03:15 PM
sdsilvere38
Oct 19, 2008 01:45 PM
JAYMONEY
Mar 23, 2008 12:30 AM
