Rocker Arm Cover - what's in the picture?
Old Mar 26, 2008 | 09:04 PM
mburnett's Avatar
Default Rocker Arm Cover - what's in the picture?
I'm finally getting my engine put back together after head gaskets and a long list of other parts. There appears to be something in the breather hose coming from the RH rocker cover. Looks like a PCV oil seperator. I have new hoses but this thing is stuck tight. The LH rocker cover has a port too but I didn't see one of these in it. Should there be one? I can't seem to find any reference to this in the Rave.
Thanks for the help,
Marv
[IMG]local://upfiles/6139/57F9790A07064B19BE09A1ECFDCFC690.jpg[/IMG]
Old Mar 26, 2008 | 09:15 PM
Default RE: Rocker Arm Cover - what's in the picture?
Some body tore up the oil separator element.
Old Mar 26, 2008 | 09:26 PM
mburnett's Avatar
Mike,
Is there only one on the RH? None on the LH port?
Old Mar 27, 2008 | 08:50 AM
okdiscoguy's Avatar
yes.
Old Mar 27, 2008 | 09:37 AM
Yes, it is like a PCV valve system.
Old Mar 27, 2008 | 10:40 AM
cplthomas's Avatar
That item is axactly what I e-mailed you about mike. I thought it was the pcv. The hose going from it to the valve cover is cracked.
Sorry for the thread hi-jack mburnett
Old Mar 27, 2008 | 09:07 PM
mburnett's Avatar
No problem. This one was stuck in the tube - packed full of solidified oil. I had to drill it to get it out. So now I'll have to order a replacement. More Disco Dollars!
rlrigsby
Nov 27, 2018 05:09 AM
SUMOSINO
Dec 10, 2014 09:02 AM
acamato
Jul 27, 2013 02:10 PM
jasonb
Oct 28, 2012 04:45 PM
vrblknch
Apr 12, 2011 09:14 PM
