rocker arm/shaft play
Old Jul 23, 2013 | 10:43 AM
  #21
I realize it may be a little late, but did you check the lifter hard surface and cam lobes for wear while you were in there, chances are they also are warn.
Old Jul 25, 2013 | 12:35 PM
  #22
acamato's Avatar
Mike, I checked a few of the lifters. They looked good (no wear). The cam lobes also looked good. All were uniform silver, except for one that has a slight brown discoloration.
Old Jul 25, 2013 | 12:39 PM
  #23
acamato's Avatar
From moving the AC/ACE/PS bracket (I slid it forward and rotated it), I developed a power steering leak. Now i have to track that down, hopefully it is just a loose hose. I need to clean that area. Since some stuff is out of the way, I can see how filthy it is. The block just behind & below the bracket is nasty, along with the front cover above the oil filter.
I am going to use Super Clean to clean it. It did an awesome job on the inside of the valve covers. I used Meguiers All Purpose Cleaner in the past to clean the engine bay, but I think super clean will cut the oil/grease better.
Old Jul 27, 2013 | 02:10 PM
  #24
acamato's Avatar
I finished up the install this morning. When I first started it, it ticked very loud for a couple of minutes then the tick went away and stayed away. I cleaned the front of the motor along with the ace and PS pump and lines.
Here's what I used/replaced:
Rocker arms
Rocker arm shafts
Oil filler o-ring
Coolant hose (intake to throttle body)
70mm idler puller
80mm idler pulley bearing
Valley gasket and end seals
Intake Plenum gasket
Throttle body gasket
Coolant pipe o-rings
Valve cover gaskets
Injector o-rings
rlrigsby
Nov 27, 2018 05:09 AM
SUMOSINO
Dec 10, 2014 09:02 AM
jasonb
Oct 28, 2012 04:45 PM
vrblknch
Apr 12, 2011 09:14 PM
mburnett
Mar 27, 2008 09:07 PM
