Rough idle, ticking sound and vibration?!?!?! What is going on?
Old Mar 26, 2007 | 12:11 PM
mr.47's Avatar
Default RE: Rough idle, ticking sound and vibration?!?!?! What is going on?
Hi
I may have found the problem, the valve cover gasket is comming out, and i got a MAF Fault code, could this slove the rough idle and vibration.
thx
Old Mar 26, 2007 | 12:35 PM
The v/c gasket won't cause the engine to idle rough.
What fault codes do you have that makes you think your MAF is bad, do you use a K&N air filter?
Mike
Old Mar 26, 2007 | 02:47 PM
geoman's Avatar
Get a compression check done. There have been numerous incidents of head gasket gasket failure that causes a "whistle-type" noise at idle from the affected cylinder. The noisewill change with rpm. And--of course-- the engine will run badly (vibrate and throw warning lights) when in this condition.
regards,
geoman
www.eurotekapg.com
Old Mar 27, 2007 | 12:37 PM
mr.47's Avatar
Hi
I am not using K&N filter, and the noiseis not a whistel its more like a pressurized air comming out in short burstand it dissappear when acclearated. And head gasket seems to be fine.
Old Mar 27, 2007 | 02:26 PM
This is a strange one, I wouldn't worry about the head gaskets, if your had one that bad that it was noisey, your engine wouldn't run at all.
Mike
Old Mar 27, 2007 | 02:45 PM
okdiscoguy's Avatar
I still say check the exhaust.
On a cold engine, start it, and feel areoung the mainfold and pipes on the side the noise is coming from. Be careful not to get burned, it gets hot quick, but there could be a hair line crack that exhaust is escaping through. Also, if you cat is getting plugged, it will make the backpressure greater, causing the sound to be worse.
Just my thoughts..
Goodluck!
dillhole
Feb 20, 2020 02:30 PM
KGN96discoSE7
Sep 23, 2017 07:23 AM
marlymarl
Oct 16, 2008 07:21 PM
krisstorms
Aug 7, 2008 04:25 PM
sandroverdisco
Jun 4, 2008 03:58 PM
