Rusty Window Regulator
Old Jan 25, 2024 | 05:02 PM
redrover75's Avatar
Default Rusty Window Regulator
This is the 2nd time that I have had a regulator rust out on me and freeze up. I siliconed where the wires enter the regulator, but this one is only a year old. Any ideas on how to prevent this in the future? I dont believe the door can be made water proof, the motor appears to have a drain on it, meaning it cannot be sealed completely. Any other thoughts are appreciated.
Thanks
Old Jan 26, 2024 | 10:16 PM
JohnZo's Avatar
Perhaps just use it more? like every time you drive.
Old Jan 28, 2024 | 07:11 PM
redrover75's Avatar
Maybe, but the internals of the window motor are rusty. there is definitely water getting into the motor, is that unavoidable?
I understand what you are saying, by using the motor it dries it out some how. which makes sense i suppose, but seems like another poor design. Third time is the charm I hope.
Old Jan 29, 2024 | 12:21 PM
adalton's Avatar
I drilled a small drainage hole on my passenger side regulator after it had failed twice. I disassembled the motor and cleaned out the rust and made a small hole for water to drain. It has been around 5 months and it has been functioning fine.
Old Jan 30, 2024 | 11:52 AM
redrover75's Avatar
Thanks, I have bigger issues now. somehow the front doors do not receive enough power to run the windows. I get about 5 volts at the motor.
roverwandeveg
Jan 29, 2019 06:43 PM
GCBurke
Jan 28, 2019 09:01 PM
wrongway1
Feb 3, 2014 12:34 AM
workinghard1713
Jun 21, 2013 01:21 PM
david1289
Mar 30, 2009 10:28 AM
