window regulator nylon nobs
For the two-piece, 3D-printed rollers search for "Shapeways" on this forum. According to the person who designed them, cement the two halves together using acetone after they are mounted on the regulator.
I replaced mine with hillman nylon washers. Cut off the old one and put the correct size in boiling water to soften them up and push them on to the peg. pretty simple, cost about $2 i think. and you can get them same day. there is a thread on it here somewhere.
