SAI blanks
Old Dec 14, 2018 | 02:06 PM
T-rex's Avatar
I spent hours trying to find something with those threads. Ended up welding them shut.
Old Dec 14, 2018 | 09:36 PM
Extinct's Avatar
You can either swap in an non-SAI ECU or have a rover shop flash a non-sai program. Take it to a shop with the tubes and hardware removed, tell them your ECU went bad and you bought the SAI ecu off ebay.
Old Dec 15, 2018 | 11:07 AM
Saturnine's Avatar
I wouldn’t mind getting rid of the stupid SAI setup on my truck.. hmmmmmmm
Old Dec 15, 2018 | 06:11 PM
GCBurke's Avatar
So if you get the non SAI ecm it would need to be flashed for your specific truck because of the bcu and alarm system ? My SAI has been removed so I get the fault codes.
Old Dec 16, 2018 | 12:26 AM
FlyingZebra34's Avatar
Talking to the guys who do our module programming for the newer Rovers. Looking into a more simple solution.
For those that deleted the system and just have check engine lights, what did you do about the vacuum lines that go to the solenoids?
Ultimately you'd just need to simulate load on the circuit for the first 30 seconds or so to make the ECM happy? I don't see any other checks than that.
Old Dec 16, 2018 | 07:16 AM
Saturnine's Avatar
I would think you would just remove any associated vac lines with the SAI delete
Old Dec 16, 2018 | 07:31 AM
Extinct's Avatar
You don't need a different ECU, you just need a non-SAI flash.
or
You can get a Non-SAI ecu/bcu/instrument cluster combination and you should have no lights, no codes
Old Dec 16, 2018 | 07:36 AM
Extinct's Avatar
Its more complicated than that. SAI ECU programming looks for the actual effect of the SAI operation, namely the extra air in the exhaust while it is running. It actually runs a test during that time looking for the 02 sensors to go lean due to the extra air, if it doesn't see that it will throw a low flow code.
The only way to get rid of the trouble codes is with a Non-SAI ecu program, either via flash or physical unit.
Scarf
Jul 9, 2018 06:56 PM
d.a.r.y.l
Jul 27, 2016 09:37 AM
knightmetro
Dec 4, 2014 09:06 AM
abran
Nov 7, 2014 09:20 AM
ajh
Nov 5, 2007 02:12 PM
