SAI tubing alternative/mod
Old 01-15-2021, 01:05 AM
JUKE179r's Avatar
I used a sharp razor blade to cut it off. Use enough pressure to slice the old hose open but not to cut into the connector itself.
Old 01-15-2021, 07:18 AM
ahab's Avatar
JUKE179r, has your pump continued to run more frequently than you remember or has that behavior abated? I know the system goes into self-test mode occasionally but recently I've been noticing my pump come on at red lights to. As soon as I press the accelerator the pump shuts off. Last night I barely came to a full stop and the light changed, I don't think the pump even got up to full speed by the time I pressed the pedal and it shut right off again. I don't remember this happening as often. I noticed it about a month ago and then it disappeared, after not having it really happen at all in the last year. And then I've heard it over the last two nights.
Old 01-15-2021, 10:37 AM
JUKE179r's Avatar
I don’t know why the pump turning on at stops problem suddenly stopped for me. My SAI pump works great since I posted about it back in August. I didn’t change anything in the SAI system or the electrics (I only installed an alternator).
These trucks are weird...
Old 01-15-2021, 10:42 AM
ahab's Avatar
OK, thanks for the response. I'll continue to monitor/ignore it for now.
Old 07-15-2022, 10:35 AM
The_OGCJR's Avatar
I know this is old but I was looking to do this exact thing. Thank you Juke!
JUKE179r (07-15-2022)
Old 04-15-2023, 11:12 PM
Discorama's Avatar
Is that mod CARB compliant? I know the smog station always inspects the emission components under the hood visually.
Old 04-16-2023, 01:54 AM
JUKE179r's Avatar
CARB compliant?
I’ve passed the annual MOT inspection here in England even after I did this mod 3 years ago. No issues or advisories from the testing centre.
Old 08-12-2024, 03:15 PM
gecko951's Avatar
I removed my hard SAI tubes and followed JUKE179r's directions for the SAI soft tube mod and everything went smoothly!
The only difference is that I ordered the following:
McMASTER-CARR 5133K25 High-Temperature Vacuum-Rated Coolant Hose, 3/4" ID, 1-1/16" OD, 5 Feet Long
Dorman Help! 47118 Heater Hose Tee
sanderjoems7
11-05-2019 04:44 PM
Hephaestus
02-28-2017 07:58 PM
CRB357
06-17-2015 07:25 PM
shonuff93
06-05-2012 05:09 PM
ajh
11-05-2007 02:12 PM
Quick Reply: SAI tubing alternative/mod
