Sealing SAI Ports (one head SAI, one not)
Old 10-12-2017, 04:05 PM
The Deputy's Avatar
Received 1,278 Likes on 897 Posts
Welded mine, too. Went to Fastenal and they had nothing, they told me to go to a hydraulic line making shop...cause the thread size and pitch was something they have/use in hydraulic fitting.
Eliminated the SAI on both our 01 and 03...and get code 1412 all the time. Don't care though, just eliminated the check engine light, mines a trail rig and when my wifes dies again...it's going to the junkyard.
Brian.
Old 10-12-2017, 07:11 PM
Jwehking's Avatar
Originally Posted by Sixpack577
Wasn't the sai only on 03 and 04??
I know its on a 2000 I just got some SAI parts from
Old 10-12-2017, 07:13 PM
Jwehking's Avatar
from RAVE to clean the threads its 5/8 x 20 TPI UNF tap class 2A if that helps you at all
Old 10-21-2017, 09:27 AM
attworth's Avatar
Originally Posted by Alex_M
I'd get two M16x1.00 20mm or 25mm length bolts and just stick them in with some thread sealant and that should work just fine.
I don’t suppose you can measure the other end? It seems the pipes are there, and not connected. If I can plug them in place that’d be nice.
Old 06-06-2018, 09:49 AM
jjtamp's Avatar
What are cons when removing SAI alltogether??? Other than fault codes obviously... How do you disable check engine light?
bwessale
09-22-2019 06:28 PM
Scarf
07-09-2018 06:56 PM
Hephaestus
02-28-2017 07:58 PM
DeepBlueWater
11-07-2007 05:33 PM
ajh
11-05-2007 02:12 PM
Quick Reply: Sealing SAI Ports (one head SAI, one not)
