seatbelt wont click in
Old May 17, 2008 | 06:39 PM
JBEGIN's Avatar
Default seatbelt wont click in
the drivers side seatbelt wont engage in my 99 discovery II. anyone experience this problem before? if so what did you have to do to fix it? i dont think its worth the ticket riding around with a seatbelt that doesnt click in.[:@]
Old May 17, 2008 | 07:00 PM
roverguy7's Avatar
Default RE: seatbelt wont click in
get a light and make sure theres nothing inside the buckle, if not, sounds like youll need a new pretensioner
Old May 17, 2008 | 07:09 PM
I had this happen on a old car that I had, if nothing is inside the latch, like a penny, paperclip,etc. Then you need a new latch. Sometimes the spring can go bad.
You can try taking a screw driver and sticking inside the latch and trying to jar the latch loose.
But most likely you need a new buckle.
Old May 17, 2008 | 07:28 PM
JBEGIN's Avatar
I dont want to break it! looks as iftheres nothing jammed in there, so probly that spring u mentioned is shot. im not sure how to take the old one out after i get a new one...
Old May 17, 2008 | 07:39 PM
It bolts to the floor of the trk. And there will be a connector plug for your warning light.
Unbolt the bad one from the floor, bolt the new one to the floor.
Old May 17, 2008 | 07:49 PM
roverguy7's Avatar
its bolted to the seat. there is a yellow sheathed connector that is for the gas charge in the buckle, not just a stalk, its a active srs componant, do not unplug it with the key on, give it a good 20 minutes of key off before you disconnect it too. and as always, be extremly careful when working with srs componants
Old May 17, 2008 | 07:56 PM
Call, http://www.roverlandparts.com/, tell them the year model and color and they can sell you a used one.
pvenuti
Sep 30, 2011 10:01 PM
Dezert Rover
Apr 29, 2011 07:22 AM
toad2
Jul 31, 2010 07:17 PM
hilltoppersx
Jul 28, 2009 04:36 PM
discoseeker
Oct 11, 2006 10:29 AM
