SERVICE ENGINE LIGHT
RE: SERVICE ENGINE LIGHT
The light bindicates that one or more of the sensors in your vehicle has detected a abnormal reading. This can be extremely minor, or fairly significant. Take your car to a dealer or a car parts store and have them read the codes from the OBD2 system. Once you have a list of fault codes post them here and someone will give you a pretty good explanation. It is usually no sweat.
JGKKME1
P0300 is random/multiple cylinder misfire detected.
P0306 is cylinder 6 misfire detected. ( this is the third cylinder, starting from the front, on the right side)
If you haven't had a change of spark plugs and plug wires this would be a good start.
May I suggest Magnacore wires and Bosch platinum spark plugs.
If you plan to change the wires yourself, it is tough to do it without removing the
upper intake manifold ( you need small hands ).
Ed
Ed
kcferna
07-07-2009 08:33 AM
blackrover
08-20-2007 06:40 PM
97LANDISCOVERY
08-19-2007 04:10 PM
