SERVICE ENGINE LIGHT
Old Jun 16, 2007 | 04:45 PM
JGKKME1's Avatar
6th Gear
Default SERVICE ENGINE LIGHT
I have a 2003 Discovery with 65000 miles and today the service engine soon light came on. What does the light indicate.
Help
Old Jun 16, 2007 | 08:48 PM
mikedemet's Avatar
Default RE: SERVICE ENGINE LIGHT
The light bindicates that one or more of the sensors in your vehicle has detected a abnormal reading. This can be extremely minor, or fairly significant. Take your car to a dealer or a car parts store and have them read the codes from the OBD2 system. Once you have a list of fault codes post them here and someone will give you a pretty good explanation. It is usually no sweat.
Old Jun 16, 2007 | 10:32 PM
okdiscoguy's Avatar
go by autozone or something similar, they will read your codes for free. It could be something as simple as a loose gas cap. Post the codes on here and we'll help you out.
Old Jun 17, 2007 | 04:47 AM
JGKKME1's Avatar
6th Gear
So the service engine soon light is the same as check engine light.
Old Jun 17, 2007 | 10:36 AM
On any of the D2's if the light comes on, you have a problem and need to check into it ASAP. So go get yours checked today and get back to use with all the fault codes.
Mike
Old Jun 17, 2007 | 11:13 AM
JGKKME1's Avatar
6th Gear
Took your advice went to AutoZone and had the disco check out - here are the two codes - P0300 and P0306. Any advice
Thanks
Old Jun 17, 2007 | 08:53 PM
EVN137's Avatar
JGKKME1
P0300 is random/multiple cylinder misfire detected.
P0306 is cylinder 6 misfire detected. ( this is the third cylinder, starting from the front, on the right side)
If you haven't had a change of spark plugs and plug wires this would be a good start.
May I suggest Magnacore wires and Bosch platinum spark plugs.
If you plan to change the wires yourself, it is tough to do it without removing the
upper intake manifold ( you need small hands ).
Ed
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
blackrover
Aug 20, 2007 06:40 PM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
97rover
Apr 13, 2005 02:19 AM
