Service engine soon *flashing*
Old Nov 23, 2010 | 08:56 AM
jareblake's Avatar
3rd Gear
Default Service engine soon *flashing*
I have had my 2000 Disco II For about a month, which i bought from a friend. It runs great and I love it; however, as I was driving back from Kansas to Oklahoma this past weekend the check engine light started flashing and there was some major hesitation in acceleration. I had put 89 oct gas in it because my friends had told me it was fine and that is what they had used. I pulled off and needed gas anyway so I put 91 oct in it and the problem began to dissipate. it didn't' do it again until the car had sat overnight and then only in the AM. it did not do it this morning and haven't seen the flashing again..could it have just been bad gas? plugs and wires? O2 sensors? i really don't have a lot of cash right now(holidays of course) and if it's something I can remedy, I will. Also, the check engine light is always on (they said it was always on and it's no big deal) but i am going to take it to have the light turned off because how will I know if something really does go wrong right..Please help!! I love this car, i sold my 2009 Saab 9-3 to have it, so I am vested!!
thanks, in advance, for your help.
Old Nov 23, 2010 | 10:00 AM
This is a waste of your time and ours till you go to your local parts store and have the codes read. Do not drive it while the lights are flashing or you will do more damage.
No, the 89 didn't hurt or cause this but you are supposed to run 91 plus.
Get the fault code numbers and get back to us with them.
Old Nov 23, 2010 | 10:15 AM
jareblake's Avatar
3rd Gear
Thanks for the reply Mike,
I didn't' know there were codes to be read, I apologize in advance for my lack of mechanical knowledge...I will go today and get the codes read..any parts store such as AutoZone or O'Riley auto? thanks again and I will get back to you with codes next time so time is not wasted...
Old Nov 23, 2010 | 12:33 PM
jareblake's Avatar
3rd Gear
Default got the codes
well, i got the codes and holy crap.....
they said when i bought it that it had had a tune up but according to the plethora of codes...you be the judge
I will start from the top
P0733; P0734; P0174; P0171; P0130; P1171; P1300; P0303-305-300-301-307-306.
needless to say i am a bit freaked out. i am taking it to a mechanic(not the one they had been using) this afternoon..does it sound like i'm totally screwed?
any help/advise would be greatly appreciated.
J
Old Nov 23, 2010 | 03:46 PM
Fireman's Avatar
You're OK, just a bit of work to do...
Here are what your codes mean:
P1300 = Random/multiple cylinder misfire detected
P0303-305-300-301-307-306 = misfire codes - last number indicates cylinder (Change your CPK, wires and plugs)
P1171, P0171 & P0174 = System too rich (bank 1) & (bank 2) (Change your O2 Sensors)
P0130 = O2 sensor circuit malfunction (bank 1, sensor 1) (Change your O2 Sensors)
P0733 & P0734 = Ratio monitoring, implausible 3rd gear & 4th gear ratio (Change or clean your MAF Sensor)
After this you should be good to go! Oh yeah, rebuild your front drive shaft.
Old Nov 23, 2010 | 05:49 PM
SDinDS's Avatar
What would concern me is the majority of the codes are on the drivers side. How many miles on it and have the head gaskets ever been done?
Eric
Old Nov 23, 2010 | 06:07 PM
Blake, send me your number and I'll call and walk you thru this.
richief556
Feb 3, 2021 04:55 PM
G Reeves
Oct 17, 2011 11:38 AM
G Reeves
Oct 16, 2011 09:31 PM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
AMANDAMC
Sep 23, 2007 11:14 AM
