'Service Engine Soon' Light
Old Apr 26, 2012 | 10:15 AM
P0440 Purge valve not sealing - from page 17-2-21 in Emission Controls part of shop manual.
Also attached is page from Bosch ECU manual, it monitors this valve performance multiple times while driving, if it does not like the performance this code will be set on the second drive cycle. So you might clear codes at the at shop, drive home, and next day it could pop up again.
But under warranty, have them fix, may impact your ability to pass emission test if needed in your area. Might be the valve, might be other parts of the system.
If you are a new owner and open the hood of the D2, it might not be the first thing that would jump out at you. There's a lot of plumbing under there. Here's a pix. Would be good to have it fixed under warranty.
File Type: pdf
File Type: pdf
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
jerrytrancik
Jan 9, 2008 05:52 PM
jerrytrancik
Dec 9, 2005 03:04 PM
Woody Reems
Nov 29, 2005 06:08 PM
rinmud
Oct 1, 2005 04:32 PM
