Shift boot
Old Jul 27, 2017 | 06:31 PM
Sixpack577's Avatar
Default Shift boot
I got new boots for the transfer case and park brake for my 04 today.
I was just thrilled to see that the park brake boot needs glued around the metal frame.
I haven't tried the transfer case boot yet, because it looks like I need to remove the center console for that.
I have searched the forum, and have found nothing.
Does anyone have any tricks for replacing these?
Thank you
Old Jul 27, 2017 | 06:51 PM
dtmbinb's Avatar
The frame is plastic and pops out of the center console. It gets glued as well. Gently pry it up with a flat screw driver. No need to remove the console.
Old Jul 27, 2017 | 07:49 PM
Luckyjayb's Avatar
x1
i just did the blacklisted engineering console plate and shift boots and used my wife's hot glue gun. Worked like a champ
Old Jul 27, 2017 | 08:46 PM
Sixpack577's Avatar
Thank you sir!
You saved me alot of time by not removing the console.
And then I would have realized after that I didn't need to.
Old Jul 27, 2017 | 08:49 PM
Sixpack577's Avatar
Originally Posted by Luckyjayb
x1
Hot glue gun!!
I didn't think of that!
I was going to use a spray glue. That would have worked, but would have taken alot longer to set up, and been very frustrating.
Thank you sir for a great idea, and saving me alot of time and headache!
Old Jul 27, 2017 | 09:03 PM
akrover90's Avatar
Yes, both are really easy and make a huge difference.
Old Jul 27, 2017 | 10:20 PM
Alex_M's Avatar
Don't pry it with a screwdriver! Rotate the base and it will come right out easily, as it was designed.
Old Jul 28, 2017 | 07:02 AM
Sixpack577's Avatar
Thank you sir!
MacRoadie
Jul 7, 2017 01:02 PM
importdave
Sep 25, 2014 10:18 PM
cfishkin
Freelander
Sep 17, 2012 10:19 PM
borderwulf
Jun 22, 2011 09:36 AM
Rover Chris
Mar 12, 2009 01:38 PM
