D II died and then was alive
Old Mar 21, 2012 | 09:42 AM
fyreles's Avatar
Default D II died and then was alive
Late last nite I took a short cut on a logging road since its mud season. The left side of the car dropped into a wet muddy rut at 15 mph. The rover coughed to a kill. Several attempted restarts and nothing. Ten minutes later the rover starts but sounds loaded up, it clears and I drive away. The service eng light came on and the s/m trans lights were flashing until I turned off the car and restarted it, service eng light remains. The mostly stock D II has two inches of lift, this was a spot I would have never thought would be a problem.
I have not been out there this morning but will get under it.
Any ideas would be great, thanks..
Old Mar 21, 2012 | 10:16 AM
Water in XYZ switch on tranny perhaps. Would be a help to know the codes.
Old Mar 21, 2012 | 10:41 AM
fyreles's Avatar
I will not be able to have it read soon, it drives normally. Should I be afraid to drive it three hundred miles ? Is this switch able to be covered ? Like I posted this was a nothing rut and I went over it slowly....I'm scared..kidding
Old Mar 21, 2012 | 12:19 PM
With no code reader, or the ever popular ultra gauge ($70) and 300 miles to the closest, you'll have to use your Jedi powers...
If the XYZ switch were to get wet and leak, it could be dried out perhaps with a hair dryer, etc. Have seen posts of guys drilling out the rivits and cleaning out the mud and re-sealing. But this might not be your problem. It is low on the transmission, mud and water not sealed so good, and makes tranny computer pout. But your results may vary.
Old Mar 21, 2012 | 01:26 PM
fyreles's Avatar
Jedi powers, I think I used all that up last night when I got the restart. I will have to haul it down to Minneapolis to the super stud non-dealer rover shop. I will say though that SVS in Duluth,MN found a cracked coolant line when I was ready to say uncle to the dreaded head gasket. Thanks for the heads up...
Old Mar 21, 2012 | 04:15 PM
There is no parts store nearby that can read code for free? Buying a reader and shipping would be less than towing 300 miles...
Old Mar 21, 2012 | 05:12 PM
So, does it now start and run OK even thought it may have some fault codes.
That sort of a ditch run in could have tripped the inerita switch?
Old Mar 22, 2012 | 11:18 AM
fyreles's Avatar
I started it yesterday, no trans lights or eng light. Runs fine. I will have it scanned when I get back from down south..
Old Mar 22, 2012 | 05:27 PM
abrady's Avatar
Crank shaft position sensor maybe? Mine did something similar a few years ago.
MurphyPeoples
Mar 11, 2015 06:01 PM
Bart Mills
Jun 2, 2014 02:02 PM
Honey Sterling
Oct 8, 2012 09:42 PM
jeffmalone
Mar 13, 2010 09:23 PM
tomdunn420
Off Topic
Feb 26, 2006 06:35 AM
