Should there be slack in the front end?
Old Jul 24, 2011 | 02:39 PM
timdunbar's Avatar
Default Should there be slack in the front end?
I had the disco on jack stands today and noticed that when I rotate the front left wheel there is some slack before the front right wheel starts to rotate the other direction and vice versa. I only ask because there is no slack in the rear end. Do I need to start sourcing front end parts?
Old Jul 25, 2011 | 06:30 AM
Would that be normal because the tires would be tracking different radius circles on a turn, and need to turn at different speeds? Wonder if it changes when you lock the diff?
Old Jul 25, 2011 | 07:35 AM
Pretty normal, if you are concerned though then drain your diff and verify there are no chunks in the oil.
Old Jul 25, 2011 | 05:48 PM
timdunbar's Avatar
Thanks Mike, I might do that.
Paul Grant
Apr 4, 2014 07:42 PM
goldenblade
Feb 11, 2012 03:13 PM
Arizona man
May 1, 2011 01:42 PM
StormTroopa
Nov 28, 2009 06:45 AM
