Shuddering steering
Old Jul 30, 2019 | 05:04 PM
Fallstaff's Avatar
Default Shuddering steering
I have the front end up trying to figure this one out: the steering felt off after having the steering cooler lines replaced.
I’m getting a visible shudder in the steering. Not smoothly across the whole range, but more in some positions than others.
Any chance this is a bleeding issue?
Or any clue as to what to be looking at, really.
Any hint is appreciated...
Old Jul 30, 2019 | 06:45 PM
Fallstaff's Avatar
Default Video
And a video. Just in case that helps...
https://www.youtube.com/watch?v=Wwwm...ature=youtu.be
Old Jul 30, 2019 | 07:28 PM
Fallstaff's Avatar
Ah ha! And it doesn't shudder when the engine is off. That seems super relevant.
Really hoping bleed and not power steering unit or pump.
Old Jul 31, 2019 | 03:23 AM
JUKE179r's Avatar
Bleeding/flushing the power steering system is easy so I'd say try that first.
Also... is your steering damper connected or going bad?
Old Jul 31, 2019 | 12:41 PM
Fallstaff's Avatar
I think I found a solution last night.
Some random googling got me to a Volvo forum... ran the steering back and forth 20 or so times with the engine off. Seems to have squeezed the air out.
Ill give it a few more goes before I lower it.
That said, some bleeding would be good. Where is the bleed screw? Looked easy in the rave, but couldn’t find it when I was underneath.
Old Jul 31, 2019 | 12:57 PM
mollusc's Avatar
that's because the bleed screw is on top of the steering box. you can't see it from underneath.
Old Jul 31, 2019 | 01:04 PM
Fallstaff's Avatar
Nope. I take that back. Just makes it better, didn’t solve.
Now to find that bleed screw.
Old Jul 31, 2019 | 08:17 PM
Fallstaff's Avatar
Okay. Been bleeding the hell out of it. Used this guy's great clear hose recirculation technique:
Did get some air out.
But it's still shuddering.
I worry that I've blown something more major. The steering pump is fairly new (although cheap), I think the only thing I haven't replaced in the system is the actual steering unit. Which of course scares the hell out of me. Those are $$$$.
I drove it after, and it feels !00 times better. Still a little off, but nothing like before.
Old Jul 31, 2019 | 10:47 PM
Dave03S's Avatar
You didn't mention the condition of the steering damper... If OG then your steering will be loose. It actually makes a huge difference if you have never updated it.
Old Aug 1, 2019 | 04:42 AM
Fallstaff's Avatar
Should be good. When I got it it was totally shot. One of the first things I replaced...
****, that actually makes it fairly old. Scary to start having things come around for the second time.
Still, pretty sure it's in decent shape...
LR03NJ
Dec 6, 2017 08:51 AM
CollieRover
Jun 28, 2017 12:11 PM
ian11
Freelander
Jun 11, 2011 07:00 AM
Long Haul
Jun 21, 2010 07:30 PM
range03
Apr 14, 2009 06:33 AM
